fog light color vs. low beam color15Integra 06-18-2004, 11:41 PM Can the fog lights be that bluish color with the low beams being a stock white color? Will that look wierd? Do the fog lights run when the low beams are on? Can you get the bluish color light from the low beams and high beams without HIDs? LMK which bulbs and which fog lights are good. How do you mount the fog lights? eckoman_pdx 06-19-2004, 07:19 PM To answer your question about fog light color, low beam andhigh beam color without HIDs...yes you can get it....check out this sticky thread..It also explains what to look for when looking at bulbs and recommends good bulbs. http://www.automotiveforums.com/vbulletin/showthread.php?t=177538 It will answer your questions there. Now, as for mounting fog lights, it depends...is it OEM ones you bought after the fact, or aftermarket. Generally aftermarket screw into the bumper. Who the fog lights run depends on who they are wired, how you wire them up. You can wire them to run with high beams, low beams, when the parking lights come on or on their own seperate switch. Automotive Network, Inc., Copyright ©2012
