oil pressure sending switch ?
DUlrich1227
06-18-2004, 03:49 PM
Where exactly is this located ?
96 GC 4.o
Thanks inadvance
Dave
DUlrich1227
06-18-2004, 04:05 PM
96 GC 4.o
Thanks inadvance
Dave
After doing a search here i think i found what i was looking for...
Its right behind the distributer cap ... How does it come out and is this where i would screw in a gauge to test pressure ?
David
Dale Aeppli
06-18-2004, 05:34 PM
David
HI YOUR RIGHT ITS RIGHT IN BACK OF THE DISTRIBUTOR THEY SCREW INTO THE ENGINE BLOCK YOU HAVE TO HAVE A FITTING TO SCREW IN TO BLOCK THEN YOU CAN :smokin: GET A FITTING TO HOOK UP A MECHANICAL GAUGE MOST MECHANICAL GAUGES HOOK UP WITH 1/8IN. COPPER TUBING . DALE :smokin:
jeepman600@aol.com
DUlrich1227
06-18-2004, 05:45 PM
jeepman600@aol.com
Thanks for the reply
1 more question..
I bought a set there are about 8 different copper pieces that came with the gauge.. Do i need to go buy something else ?
does that big piece come out ? or the piece that goes in at a right angle ? ( where the plastic plug thing is ?)
also what size are these ?
Dale Aeppli
06-18-2004, 06:51 PM
1 more question..
HI IF YOU BOUGHT A GAUGE SET THE FITTINGS TO HOOK UP SHOULD BE IN PACKAGE. JUST GUESSING THERE SHOULD BE A FITTING THAT ONE END OF FITTING SCREWS INTO ENGINE BLOCK, ON THE OTHER END OF FITTING SHOULD HAVE FITINGS TO HOOK UP THE 1/8 IN. COPPER LINE DALE jeepman600@aol.com :smokin:
DUlrich1227
06-18-2004, 07:44 PM
what about which part to unscrew i am a little unclear....
does that big piece come out ( that goes right into the engine block )? or the piece that goes in at a right angle ? ( where the plastic plug thing is ?)
thanks
dave
Dale Aeppli
06-19-2004, 11:42 AM
thanks
dave
HI, IF YOU MEAN THE SENDING UNIT REMOVE IF YOU'RE GOING TO REPLACE IT WITH THE MECHANICAI GUAGE THERE SHOULD A FIIITNG TO SCREW INTO BLOCK AND HOOK TO THE 1/8 in, line for gauge dale
