Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-17-2004, 07:19 PM   #1
ejrz01
ejrz01 Normal reputation
1991 Corolla problems starting
Hi,
My wife has a 1991 Toyota Corolla Station Wagon. It has had intermittent problems starting for the past year or so. The problem has become more and more frequent. It starts fine most of the time; however, occasionally it does nothing (no clicking). You turn the key and absolutely nothing happens. My first thought was it's a bad starter but could it be the ignition switch? Is there a way to verify that it is the starter? Any help would be appreciated... Thanks
ejrz01 is offline   Reply With Quote
Old 07-08-2004, 04:51 PM   #2
WissNX01
Banned
WissNX01's Avatar
WissNX01 Has more negative feedback than positive
Send a message via Yahoo to WissNX01
Re: 1991 Corolla problems starting
Why did you suspect the starter, then move on to the ignition switch? Always, always always, always check your fuses first. If its the starter, do you hear a clicking noise in the engine when you turn the key? If not, its a bad solenoid in the starter. You might be able to replace the solenoid, but sometiems the starter itself.
WissNX01 is offline   Reply With Quote
Old 07-09-2004, 06:35 PM   #3
Evo VII Lover
Evo VII Lover Normal reputation
Send a message via AIM to Evo VII Lover
could be the alternator, if your cars off for awhile, like my corolla, the battery will die, and it wont start.
Evo VII Lover is offline   Reply With Quote
Old 07-09-2004, 07:49 PM   #4
ishop4less
ishop4less Normal reputation
Evo, when you mention nothing happens do you mean no lights (power) as well while you try to start the ignition? First, Check battery itself and the connection make sure is tight, if the battery is not tight it will still give you power but if you try to start the car it won't be able to start just nothing happend including no lights anything, since it draw a big amp for it, but sometimes is ok, so please check the battery first. If the alternator is bad you won't be able to start at all since the battery is drain.
ishop4less is offline   Reply With Quote
Bookmarks
Google
Web AF
