Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 06-17-2004, 08:01 PM   #1
cbfloyd89gt
cbfloyd89gt Normal reputation
98 Z71 warm AC and bad fuel milage
I have a 98 Z71 extended cab with a 350 in it. It has 234K miles on it. It has not given me many problems for the milage. The other day while sitting at a red light I notice that my AC started blowing warm air. That afternoon at home I looked under the hood to see if the compressor was cycling at it is. If you drive down the road the air cools down but if you sit at idle it blows hot. Any one had this problem before? Also the fuel milage has dropped off lately. I have changed the fuel filter and plugs but that did not help much.
cbfloyd89gt is offline   Reply With Quote
Old 06-17-2004, 08:16 PM   #2
Shortbus
All hail AF
Shortbus's Avatar
Shortbus +450Shortbus +450Shortbus +450Shortbus +450Shortbus +450
Send a message via AIM to Shortbus
Re: 98 Z71 warm AC and bad fuel milage
Well there was a campaign for newer tahoes and yukons where gm added an electric condensor fan. GM claimed at a stop there was not enough airflow coming through the condensor. Based on this you might want to check and see if the fins on the condensor are pluged with dirt and debris, as well as in betweent he condensor and radiator. Other than that have a shop check the ac system pressure to make sure thats in check, if you're compressor is cycling to often or to much it may be low on 134.
Shortbus is offline   Reply With Quote
Old 06-17-2004, 09:42 PM   #3
jerrylittle
jerrylittle Normal reputation
Oxygen sensors should be changed every 100,000 you will and can loose MPG drastically when not replaced.
jerrylittle is offline   Reply With Quote
Old 06-20-2004, 09:05 AM   #4
cbfloyd89gt
Yesterday the ac compressor started makeing a funny noise. It almost sounds like it is knocking.
thanks for the tips
Bookmarks
Google
Web AF
