Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora
Old 06-15-2004, 07:30 AM   #1
patenter
patenter Normal reputation
Question smelly Jetta
Our 2002 Jetta stinks! there is a strong urine smell when we turn on the heat or a/c. and we often find white dusty chunks on the front passengers floor that have falling from the dashboard or vents. the chunks smell like mildew. the problems started last year when we had trouble with water. the rear passenger side floor was always sopping wet. it was taken to the VW place and still under warranty, but they claimed that it was not a warranteed problem. they partly blamed the installation of a replacement windshield, and partly blamed us for all the hemlock needles blocking the sun roof drains. but we are still having this problem and the floor is all moldy. the urine smell is pretty recent. the mechanic found mice nesting in the engine's air intake. he cleaned that out, but the smell persists. i have cleaned out the venting intake and replaced that filter. the VW place has tried deoderizing the car. has anyone had similar problems and found a way to solve them?
patenter is offline   Reply With Quote
Old 06-15-2004, 09:20 AM   #2
miro1118
miro1118
Re: smelly Jetta
If you still have the water problem there is really nothing that you can do until you fix it. Once it is fixed I would replace the carpets. As far as smell in the vents, when the ac is used, condensation can build up in the ventilation system. There are some products on the market that can be used to deodorize the ventilation (Try a web search). It helps to flip on the heater for a few mins after extended AC use to dry it up in there. I sprayed Fabreeze into my vents and used the heater trick and it has kept the vent smell down.
Hope this helps.
miro1118 is offline   Reply With Quote
Old 06-15-2004, 01:52 PM   #3
JettaSleeper
JettaSleeper Normal reputation
Send a message via AIM to JettaSleeper
First off...how could you have let mice find the time to build a nest in your intake??? Treat your VW with some love....drive her daily! As for the leakage, a similar situation happened to one of my buddies A6's. His car had a line that was leakin from the ac duct and was soaking his floor in the back right seat. So if this sounds familiar, bring your car to the dealer and have them check the ac lines or something. Once the leak is taken care of...the mildew will eventually clear and you can fumegate your car.
JettaSleeper is offline   Reply With Quote
Bookmarks
Google
Web AF
