Re: Towing with a Suburban 1500
you might find the rear end to be a little sloppy pulling a trailer after 94k miles, is everything still stock? otherwise, you should be ok. if not, you might look into air bags or at least new shocks.
make sure the trailer has been serviced....good bearings properly greased, tires are inflated to spec, tongue weight of trailer is good. check your trailer wheels at each stop to see if the bearings are getting hot. bring a spare trailer tire, make sure you have a jack that will work on the trailer, grease gun, and an extra hub assembly might come in handy, though hopefully not.
good luck and take it slow
