Re: power door lock
If the passenger side locks/unlocks all the doors, but the driver's side switch is only working intermittently it's gotta be the driver's side switch, switch connector or switch wire - make sure nothing's shorted too (tape up any bare metal or exposed connection (maybe something's shorting it when you put the panel back on?). As a last resort you might try replacing the switch wire anyway (in case it's broken internally where you can't see). Dunno, other than that I'm outta ideas too. Maybe someone else has a thought or two. Good luck, though...
