A606(42LE) 1995 Chrysler Concordechanda_curlin@sbcg 06-12-2004, 03:07 PM :disappoin Does anyone have any suggestions as to why the transmission A606(42LE) in my 1995 Concorde will not change gears and drags when the car gets hot. :banghead: fernjj 07-31-2004, 02:47 AM Same car, same thing happened to me. By doing a computer code check I found out it was the crankshaft position sensor that was bad. You can check here http://www.allpar.com/fix/80s-codes.html for more info. Anyway, it cost about $30, took less than 5 minutes to change and I never had a problem again. jesus9705 09-05-2004, 02:59 PM :disappoin Does anyone have any suggestions as to why the transmission A606(42LE) in my 1995 Concorde will not change gears and drags when the car gets hot. :banghead: That is the same problem i actually have..... Hey chanda_curlin .. Did you fix the car ?? what was the problem.. I think is like a solenoid or a sensor problem... About fernjj says. i have a code scanner, so i check the car with the scanner and did't found anything. Even with the Key On Off On Off method... Please help.. P.D. I have 2 week without my car.. :( fernjj 09-24-2004, 10:33 PM Also, you can check the transmission wiring harness, it passes close to the exhaust. On my car I found out that some of the insulation had melted and some of the wires would short. I was able to separate the wires and tape them up. This was causing my car to stall unexpectantly. Automotive Network, Inc., Copyright ©2012
