89GT boost problemcdmireland 06-10-2004, 11:39 AM The car was running great but suddenly it will not rev over 3k under boost. I can hear the wooosh from the turbo like the boost is being dumped by the ecu. Would a hole in the exhaust cause this? Any other ideas? Thanks 89probegt 07-13-2004, 03:36 AM you might have a vacuum leak because i had the same problem and it ended up being a vacuum leak. 89probegt 07-13-2004, 03:41 AM the hole in the exhaust, cat, has a little bit to do with it but i wouldent worry about it just check all the vacuum hoses Automotive Network, Inc., Copyright ©2012
