91 accord brake lamp onpr627 06-09-2004, 10:19 PM i have a 91 EX and the brake lamp indicator is on. checked and see that one of the bulbs on the left side with a dbl filament doesnt work. when u turn on the lights that particular bulb lights up but not for the brakes when u step on them. the one on the right side just like it works fine. put a new bulb in the left side and same problem. took working bulb from R side and put on L and same problem. is this possibly the wire harness thats bad or what ??? and whats the cost if so? lorunner 06-10-2004, 05:39 PM check the wire harness on the taillight itself. the pins on them usually corrode and if there is a little box attatched to th tailight also thats the sensor that lites the lite check that to for corrosion. pr627 06-11-2004, 09:20 AM thx lorunner. i think i have checkd all that but i may try again. i have takenthat harness out about 5 times liftedoff420 06-11-2004, 11:40 PM yo my brake lamp is always on too...but my brake lights are on what the hell is this?? FMANALOPR 06-20-2004, 10:53 AM Simple Get A Electricity Tester A Try Each Tail Light Bulb Plug And You'll Find On Has No Elec Automotive Network, Inc., Copyright ©2012
