Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > F Series
Old 06-09-2004, 09:33 AM   #1
ClydeWigg3
ClydeWigg3 Normal reputation
Angry Cold Start Problem - '91 F150 4.9L
Will crank right up then stall. Have to feather the pedal to keep it going, even then it idles very rough, coughing and sputtering until it warms up. Smokes when first cranking up. When motor is warm will crank right up without trouble.
"Fixes" to date: New fuel filter; new plugs, wires, rotor and cap; new IAC, new cold start sensor, you name it.
No codes. Fuel pressure is fine. Mechanics say it ain't the head gasket either.
After sitting for a few days (4-5) it will crank and jump into high idle and not stall, but will run roughly. If it sits just overnight, will crank and stall.
After it's warm she runs great.
ClydeWigg3 is offline   Reply With Quote
Old 06-09-2004, 12:10 PM   #2
ModMech
ModMech's Avatar
ModMech Normal reputation
Re: Cold Start Problem - '91 F150 4.9L
Check the Engine Coolant Temp sensor for accuracy. If it is reading incorrectly, you will get either too much fuel (indicates cold) or too little fuel (indicates warm). Which would account for your symptoms.
Also, be SURE you are getting BATTERY voltage to your coil while cranking.
ModMech is offline   Reply With Quote
Old 06-09-2004, 12:14 PM   #3
ClydeWigg3
Already replaced the Coolant Temp Sensor. Is there a way to test it? Concerning the battery voltage - how do you check that, and would it make a difference if the engine was hot or cold?
Old 06-11-2004, 08:57 AM   #4
97chevyman
97chevyman's Avatar
97chevyman Normal reputation
how many miles are on your oxygen sensors?
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
97chevyman is offline   Reply With Quote
Bookmarks
Google
Web AF
