E30 325iX ABS problemara12 06-09-2004, 09:10 AM Hi I owe a 1990 325iX, and i am recently having problems with the brake system in my car. First thing was that when you press on the brake pedal the pedal would start to shake under your foot as if the ABS is working even if you are going in a very low speed when the ABS is not supposed to work plus even if the car is stopped and also sometimes the ABS light would come out especially when turning the car on in the morning. I toook the car to the mechanic and cleaned the sensors and the teethof the hubs but the problem still persisted. he checked all the sensors and the ABS computer under the dash board and those seemed to be fine. The other thing is the that when you turn off the car with your foot on the pedal the pedal also shakes violently. Can anyone help with this one? thanks in advance jeffreyb4me 06-09-2004, 08:51 PM I'm assuming you've tried shutting it off with the hood open, with your hand on the ABS pump to be sure that's what's running. What else isn't working correctly on your car ? Automotive Network, Inc., Copyright ©2012
