"93": NO- GO TRANSMISIONRALPH315315 06-09-2004, 08:26 AM Hello, I Purchased A 93 Grand Caravan W/ A 3.3. 115,000 M. And No Trouble For 2 Mos. Now Van Will Run Good For About 3 City Blocks And Then Just Won't Budge. I Checked Trans Fluid And It Is Very Pink And Is Not Burnt At All, Can Anyone Help Me? Thank You, Ralph slantsixness 06-09-2004, 12:48 PM What fluid is in the tranny? If you're not sure, change it and the filter, then use ATF+3 only for fluid. Do not use dexron. Also, check your trans cooler, if it's clogged it could do this, but it means your trans has overheated and might require further repairs or rebuilding. I would do this first, then see what happens. Otherwise, there's a whole host of difficulties that could cause this, mostly requiring a rebuild in all cases. Slantsixness RALPH315315 06-10-2004, 09:19 AM Thanks I'll Try The Fluid Change Today And Let You Know, I Really Appreciate The Fast Response You Folks Are Great,have A Good One. OSUCowboy27 06-15-2004, 04:20 PM put lucas trans additive. This stuff is a miracle in a bottle. Automotive Network, Inc., Copyright ©2012
