ignition switch replaceb1tem3 06-08-2004, 09:40 PM Does anybody know how to replace ignition switch? Once i turn key to the left to turn the engine on, i have to flip the key back to the right a bit to turn accesories on. busa_4 09-07-2004, 08:58 PM the ignition switch failing is a common problem. it is in a very tight spot. you will have to go under the drivers dash and remove the air vent. it just slides out. after you remove the vent you will see the ignition switch bolted to the ignition cylinder. you will need a short pocket screwdriver to remove the screws holding the ignition switch. you will not be able to remove it without a short screwdriver. your best bet is to go by a 90 degree screwdriver with various small screwdriver bits. it is the only way. good luck! Automotive Network, Inc., Copyright ©2012
