Tranny? Fuel System? HELP! 95 3.3 160K
chateuxgato
06-08-2004, 08:00 PM
From what I've read, there are quite a few out there who have had this same problem, but there are quite a few things it could be so if anyone could be more specific, I'd sure appreciate it. I bought my 95 3.3 minivan about a year ago from the original owner. I believe it had regular maintenance, but has the original transmission. It ran great up until now. I recently moved to about 1200 feet above sea level. When traveling uphill over a mountain pass, it will start to surge and sputter as though I'm running out of gas. The RPM's will usually drop from aprox. 4000 down to 2000, surging in between. Accelaration doesn't help. I have to pump the gas pedal to get it to sputter up to the summit. It seems to be getting worse. My husband has recently employed the "FLOOR IT" technique. He opens it up until it sputters into a flat out beat-run. Usually the problem eases off upon descent. I'm hoping it's a fuel sytem problem (cheaper!) but I'm concerned because the transmission has recently started acting up in cold weather. It won't catch into drive immediately after reversing, and some times slips going out our driveway (uphill, dirt road.) Engine fault codes are 32/EGR solenoid circuit or EGR system failure (the car is from California) and 21/Oxygen sensor signal. My cousin is a Mopar-head so he can do the work, but he's not great at diagnostics. Anybody have any recommendations? By the way slantsixness, I LOVE MY VAN! You won't hear me whining even if it the transmission is circling the drain . I know a good thing when I've got it in my hands! Your messages are always helpful and courteous. I like your attitude.
RexNfx400
06-10-2004, 03:27 AM
EGR no, O2 no. These do need to be checked but, they will not cause your uphill complaint. You need a fuel pressure/flow check. You may have secondary ignition breakdown too(Thats plugs, wires and coil packs) I would bet on fuel myself.
On the tranny, its possible for the 1st design solenoid pak to act like this. Speed sensors do strange things though. Good luck
