H22A Accord Sir autobankk 06-08-2004, 02:01 PM Prelude have 200 HP on it and my Accord H22A have 190 Hp if use Ecu from Prelude will that make 10 more Hp ? Thank :) flipicaneze 08-30-2004, 11:53 PM Nope. There are different cams and compression ratios are built differently between the engines 92lx 09-01-2004, 01:30 AM I'm not sure about the compression ratios and cams, but yes, there are differences - I'd have to check up on it to see exactly what differences. But no, the ECUs should be the same. - Nathan kshawj 09-01-2004, 03:06 AM you could go head and try it. it will make a difference. the ecu maps out how much fuel its suppose to be putting out. i have seen it done on a civic. civic sohc non vtec with ls dohc ecu, it made a difference. bankk 09-05-2004, 12:32 PM i got the infomation on compression ratios and cams are the same...i found on website Automotive Network, Inc., Copyright ©2012
