Originally Posted by scottdude
You got a sunroof? If so the front drains were notorious for clogging and when they clogged the truck got full of water. Blow them out with air compressor. No sunroof check the seal around you tail lights. Good Luck
thanks - i tried looking for the drains and I saw two holes on either side of the sunroof. I'm assuming these are the ones - they both are clean. I couldn't locate any rear drain holes (if they exist). I guess next step is to check the seal around the tail lights...thanks.
