help!!!!!!!!!!!!!!!
Google
Web AF
johnboy7381
06-07-2004, 06:56 PM
i have a 1993 toyota camry,2.2 liter 4 cylinder,approx. 237k miles.i have replaced the fuel pump,strainer,fuel filter,throttle position sensor and plugs.it ran for a little bit but at low rpm's and low speed it would cut out and die.if you would play with the gas you could get it up to 80 or 90 easy.now the fuel pump will not even kick on.it turns over fine but just don't start.please help me!
thanks in advance,
johnboy
Joe W
06-07-2004, 08:29 PM
Have you run the computer for codes?
johnboy7381
06-07-2004, 08:40 PM
the ck engine light is not on to pull the codes,THANKS!!
Joe W
06-07-2004, 11:04 PM
Check to see if there is voltage to the fuel pump when the key is first turned on.If there is the new pump is suddenly old.If not check the fuses,relays and wiring.
johnboy7381
06-07-2004, 11:08 PM
ok thanks,i'll try that tomorrow.thanks again!!!
johnboy7381
06-07-2004, 11:10 PM
also do you know where the fuel pump relay is? i've looked everywhere and all over the net!!thanks again!!
mrtwo
06-08-2004, 09:27 AM
Good luck on ur problem. Do u feel the steering wheel is vibrating when u stop with the gear in drive? Mine is vibrating but not really too bad. Did u ever replace the engine mounts?
AndyM1978
06-08-2004, 09:35 AM
My Camry had similar symptoms when the distributer fried on me. I swore up and down that it was my fuel pump until my mechanic confirmed otherwise. In retrospect, it was probably just the ignition coil voltage leak issue that was common for these cars. I could have saved some money just getting that part replaced. Oh well.
johnboy7381
06-08-2004, 10:34 AM
thank you all,im gonna put it in the garage today.wish me luck!!
Joe W
06-08-2004, 05:18 PM
Let us know what it was.
johnboy7381
06-08-2004, 05:33 PM
ok,thanks,its at the garage now,i'll let you know asap.thank you again!!!!!!!!!!!
Google
Web AF
