temp gauge needle jumpsnm325e 06-06-2004, 04:14 PM During normal driving. Needle on temp gauge "swings" from mid to over heat. after about 1/2 of normal driving the gauge stabilizes a little over mid. don't know if its the thermostat or what. jeffreyb4me 06-07-2004, 09:38 PM first be sure t-stat & fan clutch are GOOD and the system is full and bled [no air]....]is it really running hot or is it a cluster problem]....check the engine first.........then if the gauge still 'bounces' around the most common fault is a loose/missing gauge nut on the back of the cluster. nm325e 07-21-2004, 11:12 AM thanks i'm thinking its a cluster issue now. once i tap on the gauge it seems to go to the mid point. Automotive Network, Inc., Copyright ©2012
