Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 06-04-2004, 07:35 PM   #1
chevysrule
chevysrule Normal reputation
Anyone have seatbelt problems?
I was just wondering if it was common for the 1990 lumina 3.1 seatbelts to not retract. I have to always manually do it but when i have passagners in my back seat and they do not retract their seatbelts they are stuck and i have to climb in the trunk and redo it all. Very fustrating!
chevysrule is offline   Reply With Quote
Old 06-04-2004, 10:57 PM   #2
cadgear
cadgear's Avatar
cadgear Normal reputation
Re: Anyone have seatbelt problems?
My 1991 Cutlass had loose rear seatbelts, but not so bad that you'd have to climb in the trunk to retract them. But they never retracted very well; I drove 700 miles from Maryland to Georgia with my rear seatbelt hanging out of the door and I didn't know about it.
cadgear is offline   Reply With Quote
Old 06-07-2004, 08:29 PM   #3
javamite
javamite Normal reputation
yeah.....mine are not as bad, but my backseat seatbelts kinda do the same thing to. I just have to pull on mine a little and they themselves back up. The front ones are cool, thankfully.
javamite is offline   Reply With Quote
Old 06-08-2004, 06:35 PM   #4
Euroguy026
Euroguy026 Normal reputation
You Guys are Lucky, My Seat Belts Retract but they wont pull out right away lol Im with a Date n i gotta wrestle with the door until it lets the seat belt come out
Beware My Euro May Be After U!
www.cardomain.com/id/euroguy026
The LUMINATOR LIVES On
Intimidator (#3 Nascar) + Lumina = Luminator
Euroguy026 is offline   Reply With Quote
Old 07-30-2004, 01:12 PM   #5
Brndo
Brndo Normal reputation
Mine had a couple of coins stuck in the reel inside the door...HA HA...took off door panel, removed the coins and fixed the problem...made 26 cents too.
Brndo is offline   Reply With Quote
Old 07-30-2004, 11:56 PM   #6
Kooterskkar
Kooterskkar Normal reputation
Send a message via AIM to Kooterskkar
Take out the seat belt spool, (the whole assembly that the belt retracts into) pull the belt out all the way. Spray just a little bit of wd40 or litium grease on the spool that holds the seat belt. Dont get it all over cuz you dont want greasy seatbelts. If you can, I dunno if theres a cover on there that you can safely take off or not, tear into the thing and clean it out.
Kooterskkar is offline   Reply With Quote
Old 01-16-2009, 11:16 AM   #7
lalunette
lalunette Normal reputation
Any kind of lubricant (grease, silicone) is preferable to WD40, which should only be used on stuck metal parts BTW.
WD40 is not a lubricant per se as it protects metal from rust and corrosion, penetrates stuck parts, displaces moisture and, strangely enough, cleans grease, grime, and other marks from most surfaces.
Therefore, if you want to lubricate the seat belt spool, use a silicone spray or grease, but not WD40.
Richard "Lada" Loiselle
Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful. Seneca
lalunette is offline   Reply With Quote
Bookmarks
Google
Web AF
