1997 Blazer intermittent key removal problem
Google
Web AF
rvtech
06-02-2004, 07:21 PM
Hi all, There is a new problem surfacing in the Blazer. It is 4WD, 4.3 auto with floor shift. Every few days, when shutting off the blazer, the ignition switch will not turn all the way to the lock position. The key can't be removed. So far, letting it set for 5 to 10 minutes & trying again works & the switch can be turned to the lock position. Any ideas where to look for problems?
Thanks, Bruce
berniescout
06-02-2004, 07:54 PM
same prob on my 97 broken wire in shift consol per service tech se my post search berniescout
rvtech
06-02-2004, 08:09 PM
Thanks, will check out this weekend
brianroot64
06-11-2004, 03:59 PM
I have the same problem on my 97 blazer. If I turn the key to the "on" position and flip the thumb button on the shifter, I hear a click in the steering column. Then the key will turn off and come out. Someone said it may be the Park sensor on the shifter.
red51953
05-24-2007, 09:56 PM
Thanks, Bruce
I have a nother problem I can remove my key all right,but when I install key and go to crank blazer there is no cluster lights coming on just the engine well turn over I can put a jumper from fuse 9 to fuse10 and the cluster lights well come on and it well start up done change ecm out on it,got any idea
ZL1power69
05-25-2007, 12:07 AM
welcome to af. this thread is now over 3 years old. please refrian from posting in threads over 6 months old. feel free to start a new thread in the problem diagnosis section.
Google
Web AF
