Changing Electric window motor *VERY URGENT*
sterobin
06-02-2004, 01:33 PM
How do i change an electric window motor on a 2000 Clio? I have taken off door panel and can see motor but where and how do i disconnet the metal wires that run to the window? My clio has some how bent its wires that connect to the window mechanism and i need to change the motor and these wires. Please help! and scanned pages from a haynes manual would be very much appreciated!!
Thanks again.
mechy1barry
06-02-2004, 02:28 PM
the motor and cables are removed and replaced as one.i think all you need is a 10mm spanner and a little brain power,not a bad job to do at all,but very exspensive!
sterobin
06-02-2004, 03:10 PM
Thanks for that. Where do u i undo the ends of the cables from? I have removed the motor from inside the door but dont know how to remove the cables as i cant see where they are attached to. I have found a scraped clio so hopefully can take that one out and put it into mine, so hopefully wont cost a lot.
mechy1barry
06-02-2004, 03:18 PM
the cables are attatched to the window riser,normally in centre of door,remove that,as i said the assembly is one complete unit.
sterobin
06-02-2004, 05:47 PM
Thanks for that I will give it a go tomorrow. And post any news good or bad afterwards!
