Engine Is Searching For Idle After Intake Mods
JEFF POLTZ
06-02-2004, 11:27 AM
Im Having Problems With My Engine Searching For Idle. It Idles Ok When Cold, But After A Few Seconds The Idle Drops Off And Surges.this Started After Installing A Throttle Body Spacer, Cold Air Intake, Cat Test Pipe, And Muffler. To Remedy The Situation I Have Adjusted The Throttle Cable To Make Sure Theres Enough Slack, Checked For Vacume Leaks By Spraying Wd-40 In The Area, Changed The Air/idle Mixture Valve (not It),
Changed The Fast Idle Valve (not It), Took The Throttle Body Spacer Off And It Still Searches For Idle. Can Anyone Out There Help Me?
E Honda
06-02-2004, 02:49 PM
Can you say throttle posistion sensor?.......
E.Honda. :banghead:
jameskersten
06-03-2004, 02:04 AM
you said you adjusted the IAC valve since this upgrade?
JEFF POLTZ
06-09-2004, 01:20 PM
E.Honda. :banghead:
YES, E HONDA, I CAN SAY THROTTLE POSITION SENSOR. I FORGOT TO MENTION THAT MY MECHANIC CHECKED THAT PART, AND THAT WASNT IT. WHAT WAS CAUSING ALL THE PROBLEMS WAS THE IDLE ADJUSTMENT SCREW. I DIDNT TOUCH IT, I DONT HAVE A WRENCH TO FIT IT, SO WE DIDNT EVEN CONSIDER THAT. I TALKED TO THE GUY I BOUGHT THE CAR FROM, AND HE MENTIONED THAT THESE ENGINES ARE SUPPOSED TO IDLE AT A CERTAIN RPM, OR IT WILL CAUSE THAT PROBLEM. AS SOON AS MY MECHANIC CRACKED THE NUT ON THE SCREW, THE SURGING STOPPED. I WAS BOTH HAPPY AND PISSED,THAT IT WAS SOMETHING SO SIMPLE. MY MECHANIC ONLY CHARGED ME $30. WHICH I THINK IS VERY REASONABLE, CONSIDERING THAT I HAD IT TO HIM 4 TIMES, PUTTING NEW PARTS ON AND TAKING THEM OFF AND REPLACING MY OLD ONES. THE CAR IDLES FINE NOW, RUNS GREAT, BUT A LITTLE LESS MPG BECAUSE OF THE BOLT ONS. IM HAPPY FOR NOW.
jameskersten
06-09-2004, 09:35 PM
it seems it always the simplist thing
