check engine light
lighterside
06-01-2004, 08:25 PM
I have a 97 ranger that had the check engine light come on. I went to auto zone and they said it was a code p01443 which I know could be the gas cap and I checked the seal on that and it looks good. Does anyone know what else it could be and if I may be able to fix it on my own? I am in a bind right now with cash and don't know a lot about cars.
splashiod
06-02-2004, 09:22 AM
It's a good chance that it's a vacuum leak somewhere. I just had the same code & it was the hose going in/out of the carbon canister (below battery). Does the truck run any different? You can start the truck & sray carb cleaner on vaccum hoses & if idle changes, that's where your leak is. Good Luck!
2000mudder
06-03-2004, 12:29 AM
P0443
EVAP System Purge Volume Control Valve Circuit Malfunction
Is this your code?if so start checking for a vacume leak. hoses,evap service port and sensor(on drivers fenderwell behind brake lines)large line to tank.
GEdge
06-15-2004, 12:16 PM
I also have a '97 and have the following three codes:
P1443 (Evaporative Emission Control Systems Control Valve)
P0171 (Too Lean Bank 1)
P0174 (Too Lean Bank 2)
Is this likely to be vacuum leaks as well?
Thanks.
splashiod
06-16-2004, 10:24 AM
Thanks.
P1443 is probably vacuum leak.
PO171 & PO174 are bad 02 sensors. check out this link http://www.rangerpowersports.com/forum/showthread.php?s=&threadid=109108&highlight=p171
Pushrod
06-16-2004, 09:29 PM
Thanks.
The problem is probally your 02 sensors, but don't forget some models had 4 of them, you will find 2 more around you cat. converter, check those also............Good Luck.
theyman
06-25-2004, 12:12 AM
i just had that problem with my 95 and it was a sensor
GEdge
06-25-2004, 09:38 AM
Theyman:
Which sensor was it?
Thanks.
GEdge
07-01-2004, 12:43 PM
I traced the vacuum line from the fuel tank to the vapor cannister. No apparent leaks - I removed the rubber hose section and checked it for leaks and found none. After replacing it, two of the codes previously reported are now gone:
P0171
P0174
so I conclude that the hose must have been loose at the fittings. Previously I had replaced the gas cap with no change to the code readings.
The P1443 code remains on.
Suggestions for the P1443 code?
Thanks.
splashiod
07-02-2004, 11:52 AM
P0171
P0174
Thanks.
I've heard the TPS & IAC sensors can cause that code, but not sure. I just got the code again on my 95 but haven't looked yet. I bet the PO171 & PO174 codes come back after time because from what I've heard they are O2 sensor codes, but good luck!
GEdge
07-06-2004, 10:18 AM
You were right about the codes coming back after about a week. I guess this means I need to replace the O2 sensors .... ???
BLUBALZ
07-21-2004, 08:37 PM
I Had The Same Problem, So I Replaced The Sensors, That Didn't Fix The Problem. The Engine Was Burning Rich, "maybe A Sign That The Cat. Converter Is Pluged Up", So I Replaced The Cat. Converter And The Check Engine Light Doesn't Turn On Anymore.
GEdge
07-22-2004, 10:51 AM
Did you put in the CAT yourself? I do most of my own work, but haven't replaced a CAT in these trucks. Wondering whether it is welded or clamped in place and whether there is some other option for cleaning or clearing it. Last time I had to replace one on the wife's Explorer it was not cheap.
Car Pal
07-22-2004, 08:24 PM
1443 is purge flow solenoid.there is also a flow sensor inline with it.replace em both.l71,174 could be the vacuum lin that runs into the air cleaner tube being off.
GEdge
07-23-2004, 11:22 AM
Having trouble locating the replacement purge flow solenoid and sensor through the usual internet parts outlets. Anyone know where I can order these?
GEdge
11-01-2004, 11:26 AM
I finally wrung this one out - Intake Plenum gasket was leaking slightly - not enough to really affect performance, but the slight vacuum leak set the sensors off.
Have 500 miles on the new gasket and no further problems so I am very confident this was the culprit.
casperslee
06-03-2005, 09:05 AM
ROCKAUTO.COM
GEdge
06-03-2005, 10:30 AM
ROCKAUTO.COM
Thanks - got this done during Christmas break....
Greg
