airbag light is back ontacoma man. 06-01-2004, 06:08 PM this time it came back on when i plugged in my cell phone charger into the right side accessory outlet. the light came on and wont go off. need help. big_john 06-02-2004, 10:18 AM Just a suggestion, but take it back to the dealer and if a "low-voltage" code is again detected, have the dealer check for a loose connection that has your airbag and accessory socket on the same circuit. Sounds as if a common voltage supply wire may be the problem if it is not making a good connection somewhere. A cell phone charger only draws a couple of amps of current and shouldn't pull down the voltage that much. The key is that apparently both (airbag and accessory jacks) are on the same circuit. Go from there. Good luck. tacoma man. 06-03-2004, 01:38 AM thanks. i will check it out, i bought this truck from a bank, it was a repo. so no warranty, i did install a foglight switch around the accessory pugs....i may have accidently unplugged something. Automotive Network, Inc., Copyright ©2012
