Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 05-31-2004, 04:20 PM   #1
funkamongus20
funkamongus20 Normal reputation
97 blazer wont start. Please help, its my only ride.
I have spark, I hear the fuel pump come on. I changed the fuel filter, put gas in the carb, it started rough and kept running then ran for a week and stopped again. SES light has been on a while. I already changed 2- O2 sensors and it came right back on. There are four of them. I assumed they would all go about the same time and was told it really only affected your emmisions and your mileage a little. so Ive left it for a while. Related? Is it worth buying a OBD2 scanner if your really broke. Please help, its my only vehicle and Im stranded. THank you
funkamongus20 is offline   Reply With Quote
Old 06-01-2004, 09:40 AM   #2
cybermoser
cybermoser Normal reputation
Re: 97 blazer wont start. Please help, its my only ride.
I had the same problem with my 97 blazer. Here is what you need to do. Go get yourself a fuel pressure gage and check the fuel pressure on your engine. Looking in the Chilton's manual for the 97 S-10 Blazer under Fuel Testing page 5-10, item 7. "Monitor the fuel pressure with the pump running. The pressure should be 60-66 psi (415-455 kPa)." If your pressure is below 60 psi. IT WILL NOT START!!!! If it don't start, hook up jumper cables to another vehicle and then try and start it, this normally give the fuel pump more electricity therfor upping your fuel pressure and allowing it to start. I think you need a new fuel pump. But first try the items I told you about.
Best of luck..
cybermoser is offline   Reply With Quote
Old 06-01-2004, 06:48 PM   #3
Rbraczyk
Rbraczyk Normal reputation
Send a message via AIM to Rbraczyk
if you have an autozone nearby, they scan OBD2 codes for free.
Rbraczyk is offline   Reply With Quote
Bookmarks
Google
Web AF
