Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 05-31-2004, 03:20 PM   #1
Ilya
Ilya Normal reputation
question about a leak inside blazer
hey guys, my dad has a 97 blazer 4 door, 4x4, and this is his problem.
He had a passenger side leak inside the cabin, we thought it was the rubber seal around the doors but it was not.
Anyways we took stuff appart and found where leak is comming from
Under the passenger side dash, where bunch of wires are, (have to remove the plastic panel) there is some sort of thing that attaches to firewall and it has a roundish container with a little tube going to it,
well the thing has this door, when u press it it opens up.
So when it rains water collects there and starts to leak through that door. When it was raining i pressed on the door and water just poured from there like crazy,
Just wondering if any one knows how to fix that,? (maybe some one had similar problem) maybe the drain is clogged or something? I would appreciate some insight on this, if some one knows about it please reply
thank you
Ilya
Ilya is offline   Reply With Quote
Old 06-04-2004, 02:18 PM   #2
Ilya
Re: question about a leak inside blazer
any one?
maybe i should remove that piece , did any one remove the dash on blazer b4? how long does it take and is it a pain in the .. .
thanx
Old 06-04-2004, 02:19 PM   #3
Ilya
how long does it take to remove the dash on blazeR? is it hard?
Old 06-05-2004, 12:48 PM   #4
Blazing Rice
Blazing Rice Normal reputation
removing the dashboard is complicated process, not something I would suggest a novice attempt. I'm not sure what you're talking about as far as the device on the firewall. Can you remove it?
Blazing Rice is offline   Reply With Quote
Old 06-05-2004, 01:36 PM   #5
Ilya
YES I BELEIVE U CAN REMOVE IT, but dash is in way, its on passenger side, if u remove lower plastic trim where wires are, you can see it, it goes into the firewall, and has this round reservoir looking thing with hose going to it
not sure what that is, but thats where its leaking from
Old 06-05-2004, 05:44 PM   #6
Blazing Rice
Can it be removed from underhood? Can it be seen from underhood? I want to say that it may be part of the heating system but I'm not positive.
Old 06-05-2004, 06:54 PM   #7
Ilya
no it can not be removed from underhood, only from inside, it has 4 bolts holding it, i got those off , but the dash is in way for me to remove it fully
Old 06-05-2004, 10:29 PM   #8
cobra1
cobra1
sounds like your talking about a vacuum actuator for the vent system.
if the water is getting in there, then the leak is further ahead of that, most likely in the cowl below the windshield.
if so, your most likely looking at removing the hood, and wiper arms to get the cowl covers off to get to where the air is drawn in from. once the cowl covers are off, be sure to check that any/all drain holes in the cowl area that drain to the engine side of the firewall arent stopped up.
without seeing it, thats the best i can offer.
cobra1 is offline   Reply With Quote
Old 06-05-2004, 10:39 PM   #9
Ilya
cobra1 , thanx man, i ll try that , but i think they had the cowl cover off and did not find nothing wrong, i guess i ll take a pic and post here to show
thanx
Old 08-01-2004, 11:47 PM   #10
Ilya
got it fixed, 250 bux, it was clogged condenser or something, they had to remove the panel to get to it, but now is good, thanx guys
Bookmarks
Google
Web AF
