99 ranger overheatingtonyboy 05-31-2004, 02:00 PM I have a 99 Ranger 4.0L, as I drive around high way or streets the temp gauge slowly climbs up to the (H) and slowly goes back down to about half way between the normal temp and high then slowly climbs back up. any Ideas, I'm good on antifreeze, the upper hose is very hot. I tried turning on the heater but it doesn't seem to make any difference, could the waterpump be at fault?, thanks chaser29 05-31-2004, 11:34 PM Replace the " thermastat. " The current one is probaly shot! Also recheck your fluids or just drain the system, flush, then refill. The thermastat cost $2.00. I have a 99 as well. Good Luck. http://members.cardomain.com/12311974 I have tonyboy 05-31-2004, 11:44 PM thanks for the help I replaced the T-stat and all is good, thanks again. biochip 10-11-2004, 03:40 PM I am also having the same overheating problem with my 99 ranger. Will try replacing T-stat. Anyone else have problems with front brakes? tonyboy 10-12-2004, 12:30 AM Yeah the T-stat should absolutely be the solution, my front brakes have always givin me problems every 6 months the front dics are gone. I still haven't quite solved the problem. I've head that ceramic pads really help on the rangers. 76cobraII 10-18-2004, 06:04 PM T-stat will fix the overheating. As far as Brakes go. Autozone has lifetime warratny pads for about 20 bucks. I'm still changing the pads on my 94 ranger every 8 months or so, but at least it's not costing anything. Automotive Network, Inc., Copyright ©2012
