Spoon drain plugs
Ricochet
05-30-2004, 09:35 PM
Is this worth buying for a daily driver? I mean isn't it already a bad thing if you have metallic debris floating around in your oil?
http://inlinefour.com/spoonspormag.html
CivicSpoon
05-30-2004, 09:46 PM
I'd probably buy them if I did a turbo or use it for the first oil change after doing motor work; then replace it with an OE one after that.
Ace$nyper
05-30-2004, 10:02 PM
I can't see it being a bad idea. I mean will it help i dont know but will it hurt no.
Worse to worse its some cash for a mad tyte JDM spoon part.
If someone can vouch for usefullness i'll get one
It sounds legit theroy but too good to be true so IDK
Ricochet
05-30-2004, 10:16 PM
$48 is way too expensive for one. Researched a bit and they sell magnets for the oil filter for $10 at any autozone or whatever.
Ace$nyper
05-30-2004, 10:19 PM
but but but are they JDM yo ?
38 more is worth it to be JDM you know?
ROFL no really thanks for teh info man much better idea
Ricochet
05-30-2004, 10:25 PM
haha, roll up to a show and have a red cardboard arrow laying on the ground "jdm drain plug"
unusualcivic
05-31-2004, 12:38 AM
believe it or not, it is a good idea to have the magnet, it keeps metal (from what i dont know) from chewing up bearings and all, but i just cant justify 50 bucks for the spoon name. :dunno:
Ricochet
05-31-2004, 12:50 AM
Yeah but if you have metal shavings floating around doesn't that mean your engine's already fucked?
unusualcivic
05-31-2004, 01:04 AM
i know for a fact when a motor is broken in for the first time it puts out a crazy amount of shavings from the rings seating into the cylinder walls, other than that im not very sure. however there are a lot of times very small amounts of metal floating around, think about it, if the motor didnt shave any metal off at all, what would make them wear out?
Ricochet
05-31-2004, 04:12 AM
true.. guess they're really really small shavings then
Ace$nyper
05-31-2004, 06:18 PM
hmm so maybe its worth it. I guess i'll get that cardboard arrow too
SiGNAL748
05-31-2004, 06:34 PM
Aye y0 dawg, u mos def gotta get sum of tha spoon plugs. ish JDM y0!
Anyway, i'd have to say that the spoon ones are definitely too expensive. but having the magnetic plug does sound like a good idea.
ebay anyone?
udelblue
06-02-2004, 09:01 AM
http://www.filtermag.com/
I Highly recommend getting better than magnetic plug plus you can use it in combination with plug.
crxlvr
06-02-2004, 09:31 AM
man, for 48 bux i cant get a set of 5 magnetic plugs, a lap dance and a corona.
