Ripped CV Boot
NicB.
05-30-2004, 02:37 PM
Can anyone can give me info on replacing a ripped Outer CV Boot - I would really appreciate it. Any diagrams or places on the net I can get pics and or a process of how to do it, what tools I need, etc. would be super.
Thanks,
NicB.
yotatechie04
05-30-2004, 05:18 PM
What year and engine?
ToyotaTech1
06-07-2004, 10:48 PM
You will need
Breaker bar
30mm socket
14mm socket
17mm socket
10 mm socket
Pry bar
Cv boot pliers
snap ring pliers
dikes
1- remove the cotter pin and the nut at the end of the axle
2-remove the 14 nut from the sway bar link where it attaches to the strut.
3- remove 10mm bolt that holds the abs wire on the inner fender( this will allow you to move the strut out without breaking the wire.
4- remove the 2 17mm nuts and 1 bolt underneath the lower control arm.
5-Pry on the end of the lower control arm ans separate the control arm from the strut.
6- pry the inside of the cv axle out of the transaxle
7- remove the rings that hold in the inner boot first
8- once you get the inner boot off you will see a snap ring on top of the y shaped thing remove it.
9- remove the y shaped thing by tapping ouwards with a small hammer.
10- remove the outer boot
11-Install new boots in reverse order
Good Luck
