advanced timing
boosted k20
05-30-2004, 02:10 AM
is it a good idea to advance the timing in my car? how much more HP does it really make? i know im gonna have to use 91 or higher octane fuel if i advance the timing. is it even worth it to advance it?
Oldteg
05-30-2004, 12:24 PM
can I ask you this? Why is your nickname boosted and you have a turbo timer and no turbo? If you had a turbo, you should have your timing bumped up already.
To answer your question, it won't give you a whole lot of power but you will notice better throttle response. You will want to run atleast 91 ( you should be already if you are boosted.)
boosted k20
05-30-2004, 12:37 PM
you know how many times i get asked that question. I just choose that name because im in love with the RSX and hope to have one within 2 years and will plan on boost n it.
and bout the turbo timer, i just got it for a really cheap price (20 bucks) and just installed it in my car. no harm in have n a turbo timer in a non turbo car right!
so it wont give me noticable power if i advance the timing. so i should scratch that idea right?
Oldteg
05-30-2004, 01:13 PM
I wouldnt scrtach the idea. Its so easy to do, you may as well do it. I did it and like I said, I noticed a bit better throttle response. Every little bit helps in my opinion.
boosted k20
05-31-2004, 12:44 PM
so how do you advance the timing? you have to remove the distributor and turn the rotor a little bit right?
how did u go about do n it?
i dont wanna mess anything up and give it too much advance in timing.... detonation!
Oldteg
05-31-2004, 08:57 PM
Just make sure you have a light.
1. loosen up all the distributor bolts with a 12 mm wrench. dont take them out.
2. turn the distributor towards the firewall untill you get to about 3 degrees
3. tighten it back up and your done.
I wouldnt go anymore than 3 degrees. It's very easy.
sameintheend01
06-01-2004, 01:25 AM
uhh, if u are boosted, u would retard your timing...
Oldteg
06-01-2004, 10:28 AM
my bad. I wasnt thinking.
boosted k20
06-01-2004, 03:24 PM
yea my name is "boosted k20" but im a N/A integra =)
so get a timing light and turn it towards the firwall. i'll try it...
i'll have one a my friends who owns a shop, make sure im doing everything right.... i dont want to put too much timing and blow my motor =/
