check engine light and codes p401 & p402waggy 05-29-2004, 06:31 PM I had the check engine light come one. so i went to autozone to get the codes. It comes up with both p401 insufficent flow detected and P402 excessive flow detected. ok im at a lose on what it could be? anyone have any ideas? irish30 05-31-2004, 10:48 AM You need to replace your DPFE (Delta or Differential Pressure Feedback E.G.R.) sensor. It helps regulate the amount of E.G.R. flow that is needed. It is located on the intake manifold and has two rubber hoses attached to it. It is screwed on with two 7mm screws. It is black on the 2001 taurus and is about 2 1/2" by 1.5" rectangular shape. If the engine light is still on then disconnect your battery after you change the sensor. Leave it disconnected for about 1/2 hr. This will clear the engine light for you. :sunglasse waggy 05-31-2004, 01:48 PM ok great! you wouldnt have the part number? I looked on autozone.com and napaonline and neither have the DPFE etc. irish30 06-01-2004, 12:40 AM Not sure but where you are it might be a dealer part. You could always post a new thread for purchasing a DPFE and see what others have access to. :sly: waggy 06-18-2004, 03:07 PM Ok. I called the dealer to try to get the part number. they said i was in luck since it is covered under a recall! wee! i get it replaced for free. wobbles55 08-30-2004, 06:25 PM Ok. I called the dealer to try to get the part number. they said i was in luck since it is covered under a recall! wee! i get it replaced for free. Waggie, Would you mind posting the recall number for the DPFE sensor? My dealer says he hasn't heard of a recall for a 2001 Ford Taurus for a DPFE. Thanks. waggy 08-31-2004, 12:22 AM Waggie, Would you mind posting the recall number for the DPFE sensor? My dealer says he hasn't heard of a recall for a 2001 Ford Taurus for a DPFE. Thanks. well i didnt get any paper work ok it. I just mentioned that i heard there was a re-call on it. They called back later and said yeap there is one. I did get the work order. but i lost it (just baught a new house and moved) Automotive Network, Inc., Copyright ©2012
