M.A.P SensorG2integra90 05-28-2004, 11:41 PM I have a 90 Acura Integra, And i throwing a code 3 and 5. Which is M.A.P sensor, Where is the map sensor located under the hood? and how much is it? i call autozone and they said that they dont carry it. charlieteg 05-28-2004, 11:46 PM if i am right it is on your throttle body but i am not sure boosted k20 05-28-2004, 11:52 PM it's either on your throttle body or on your intake manifold, i cant remeber =/ It's a little black plastic thing that has three wires coming out of it. if im not mistaken, you should see the words "denso" and it should say "MAP" sensor on the sensor but once again not too sure. geojim 05-29-2004, 06:07 PM On my '92 Integra the MAP sensor is mounted under the hood on the firewall, closer to the driver side. Double check that the electrical connector is well seated, and that the vacuum hose is not cracked or blocked. Change the vacuum hose if there is any doubt. Automotive Network, Inc., Copyright ©2012
