ford granada EEC-IV help wantednay27uk 05-28-2004, 11:44 AM Can anyone tell me the procedure for reseting the ECU on a 2.0 injection pinto powerd car. Thge ecu is the EEC-IV. Also can anyone please tell me the timing mark to use on the bottom pully for the smae engine 2.0 injection granada pinto engin i only have a manual for the 2.0 standerd pinto non injection and that says 4 degrees but is it the same for the injection. THANKS in advance 91_T-Bird_HO_5.0 06-11-2004, 03:56 AM normally if you take the negative battery terminal off for about 15 seconds that will reset the computer mechy1barry 06-11-2004, 03:10 PM yep,ditto that-if you want timing set up data sent please email me with engine code,i.e,ne4-nel-nra/nri,assume this is 85 to 89? 91_T-Bird_HO_5.0 06-12-2004, 01:53 AM i can't remember where i heard this from, but you can check your codes with a simple volt meter by watching how many strokes the needle makes, i can't remember where you're supposed to hook it up though :/ Automotive Network, Inc., Copyright ©2012
