Originally Posted by Diamondshoals
I've got the "gas cap loose" (small leak detected - code 102) code on my '99 Tahoe... it's not, of course, but how can I reset the SES light for this problem??
Thanks
Bob
The P0102 is a MAF code.
The P0442 is a EVAP small leak detected code.
On rare occasions this can be caused by a loose gas cap, most of the time this code is a result of some kind of EVAP system failure that will produce a leak such as a cracked EVAP line, leaking fuel tank seal or other EVAP componant.
Although resetting the light will cause the SES light to go out, you still have not addressed the cause of the problem, just the effect.
