Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 05-25-2004, 11:53 AM   #1
GAGT98
GAGT98 Normal reputation
Send a message via AIM to GAGT98 Send a message via Yahoo to GAGT98
Unhappy Blue Smoke Exhaust
my 98 GT is running just fine. i just bought it 1 month ago for 4,995 with 65,000 miles. but now im starting to have trouble with a little puff of blue smoke coming out of the exhaust. anyone have any ideas or have this problem? message me on AIM or YIM or reply on here. i really appreciate anyones advice.
GAGT98 is offline   Reply With Quote
Old 05-25-2004, 03:50 PM   #2
GRANDAMLD9
Banned
GRANDAMLD9 Normal reputation
Send a message via AIM to GRANDAMLD9
Re: Blue Smoke Exhaust
i cant think at the moment but i think blue is antifreeze. and white is oil. what motor do you have in your car?
GRANDAMLD9 is offline   Reply With Quote
Old 05-25-2004, 03:52 PM   #3
GAGT98
Blue in Oil....i have a Quad 4
Old 05-25-2004, 07:39 PM   #4
Slade901
Slade901's Avatar
Slade901 0
Blue = Oil
White = Coolant
Black = Excess gas
Sometimes a black smoke might also have a white smoke and a combination of excess gas and coolant.
1999 Dodge Truck RAM 1500 1/2 ton 4WD V8 360 Z 5.9L SFI QUAD CAB Sport Ed
1999 HONDA TRUCK PASSPORT 4WD V6 03165 3.2L MFI
1997 MERCURY SABLE 6 Cylinders 182 U 3.0L SFI
1994 PONTIAC GRAND AM L4 138 3 2.3L MFI SOHC QUAD
1990 OLDSMOBILE CUTLASS V6 191 T 3.1L MFI
1981 MERCEDES BENZ 240D 4 Cylinders 02399 2.4L DIESEL
Slade901 is offline   Reply With Quote
Old 05-25-2004, 07:40 PM   #5
GAGT98
But what do i do?
Old 05-25-2004, 07:53 PM   #6
Slade901
Slade901's Avatar
Slade901 0
Valve seals is usually the culprit. Oil is getting past the valve oil seals and getting into the combustion chamber.
Valve seals needs to be replaced.
However, try using a thicker oil and see if it minimize burning oil.
Old 05-25-2004, 07:54 PM   #7
GAGT98
ok will try thank you
Old 05-26-2004, 05:54 AM   #8
GTP Dad
Pontiac Guy
GTP Dad Normal reputation
You might also want to try a product called Restore. You mix it with your oil and it will stop most oil burning from either rings or valve seals. It will mix with any type of oil. You should also see some improvement in power as it is designed to fill in scratches in the cylinder walls that decrease compression. You can get at most auto retailers and they even sell it at WalMart. I have used it and it works very well.
GTP Dad is offline   Reply With Quote
Old 05-26-2004, 08:57 AM   #9
Markgase2000
Markgase2000's Avatar
Markgase2000 Normal reputation
Send a message via Yahoo to Markgase2000
Black = carbon
White = burning coolent in engine or running rich fuel
black and blue = burns alot of oil
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Markgase2000 is offline   Reply With Quote
Old 05-26-2004, 09:05 AM   #10
CarSuperfreak
CarSuperfreak's Avatar
CarSuperfreak Normal reputation
Send a message via AIM to CarSuperfreak
My car burns a little oil netween oil changes, but with 140K, this is expected. I have been using Valvolines Max-Life Oil, and I'm pretty convinced that it works. It claims that it has special detergents in it to help recondition brittle seals in the engine, thus restoring their ability to seal. While there is going to be no miracle healing of your car, you might try this, and just see if it at least helps.
CarSuperfreak is offline   Reply With Quote
Old 05-27-2004, 11:43 PM   #11
Slade901
Slade901's Avatar
Slade901 0
You might want to replace the PCV valve. If PCV valve fails, (stuck open) it will allow air/oil mixture to the intake unrestricted.
If PCV valve fails, (stuck closed), it will allow the air/oil mixture to force backwards into the breather hose and into the intake hose.
Bookmarks
Google
Web AF
