No Sparkmovieman 05-25-2004, 11:37 AM Hi I have a honda civic dx and I did an engine swap with a vtech b16a engine and sent the wiring harness out to be converted. Everything went good with the swap, now when I go to start the engine it won't fire and there is no spark to the sparkplug, I replaced the distributor with a new one and still the same thing. what could be the problem with the spark, and what should I do to check where the problem might be. I am sure once I get spark to the plugs it will start. Any suggestions will help. :banghead: integrasedan 05-25-2004, 03:52 PM make sure you put back the ground wires after the swap. then check ignitor and sparkplug wires. movieman 05-25-2004, 08:48 PM Ok I am pretty sure all the ground wires are back on and tight to the engine and chassis ,Think there was 3 grounds, where is the ingnitor and how do I check this? Also if anyone knows where I can find a manual for this engine I would appreciate it. integrasedan 05-26-2004, 09:44 PM it's in the distributor along with the coil, but then again you replaced it. Check for blown fuses. movieman 05-27-2004, 09:53 AM Ok thanks , I will check all the fuses and hopefully that is the problem. Ohterwise I will have to take it to a dealer or someone that knows about hondas, and thats what I am trying to avoid, because of the cost. :2cents: murata2k 07-08-2004, 01:18 AM Not sure if the distributor is the same but I had the same problem in my stock 91 dx hatchback and it turned out to be the ignition modual. I also repleced the ignition coil which is also inside the distributor. Rebuilding one isn't very hard at all, but it was kind of expensive since I also replaced the distributor. But hey! Runs great now... Automotive Network, Inc., Copyright ©2012
