Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Explorer/Explorer Sport Trac
Old 05-25-2004, 11:11 AM   #1
dtravis
dtravis Normal reputation
94 explorer transmission
At times, my 94 Explorer with 75000 miles will shift out of overdrive and not go back in. Usually when it is cold, it goes in OD and will do fine for about 5-10 miles of highway/interstate driving. Then it will shift down out of overdrive and won't go back in until I let it set overnight. Transmission fluid exchange and filter done about 10k miles ago. The problem just started and is sporadic. Usually not a problem when driving less than 15-20 miles. After driving at highway speed for 10 -15 minutes the problem usually occurs. Otherwise, transmission operation is perfect. Please help.
Since this post, it now does not go into overdrive at all, even when I first start out in the morning.
dtravis is offline   Reply With Quote
Old 05-25-2004, 09:58 PM   #2
mabulok
mabulok Normal reputation
I read somewhere that voltage problems can cause a/t issues. Apparently the explorer o/d is controlled by voltage and any change in voltage might cause the tranny to change gears. Take a look at your alternator/regulator. This is a ripe age if you've still got the original alternator in there. It might not be apparent due to variances in operating temperature, driving conditions, etc. But it's a start. Also be sure and check out all your wiring harnesses. It can also be caused by poor connections, intermittent shorting, etc. Pay particular attention to those harnesses that come close to any exhaust pipes. Hope this helps. Good luck.
mabulok is offline   Reply With Quote
Old 05-26-2004, 01:50 AM   #3
RexNfx400
RexNfx400's Avatar
RexNfx400 Normal reputation
Re: 94 explorer transmission
Probably the TCC(torque converter clutch) is unlocking. TCC can "feel" like a shift, but it really isn't considerd a shift. Its always the first thing to show symptoms when there is an electrical problem. Someone needs to monitor computer data stream on the TPS, TCC, MAP and more. With a scan tool...
RexNfx400 is offline   Reply With Quote
Old 05-30-2004, 10:35 PM   #4
luis1
luis1 Normal reputation
theres some transmission control soleniods in the valve body . it is a task , i recommend having a trans specialist take a look at it.
luis1 is offline   Reply With Quote
Bookmarks
Google
Web AF
