97 cavalier left turn signal light need bulb replacement
cyndezign
05-24-2004, 11:46 PM
The inside dash light for the left turn single blinks fast and the outside turn single doesn't come on at all. All the other signal lights work fine - the emergency flashers all work except for the left front blinker. I have checked the fuse - it is good - how do I check to see if the bulb needs replacement? It is very difficult to get at - Is there an easy way to check and or change the bulb? The bulb part number is 3357. Any info would be much appreciated.
Thx
Miltrez
05-25-2004, 08:34 AM
Thx
The bulb itself is a cheap fix. Getting at it like you said might be difficult, but after poring over my Haynes manual, there is really no other way to test a bulb. Even if the bulb was not bad, you will still have to get in after it to reseat (not likely the problem) it or fix it. The fast blinking is your warning that the lights are not working properly.
Classicrocjunkie
06-18-2004, 12:29 AM
Well if you need to get at the bulb and actually pull it out to see if its brokin, just remove the headlamp above it and its right there.
