Transmission 3.1 95 Lumina Sedan- Hard Reverse
WBoyd
05-24-2004, 04:43 PM
We have an intermittant hard shift into reverse gear. Have to speed up engine for reverse to engage. Otherwise xmsn runs smooth. Something simple to fix or overall?
SlamminMOfo
05-24-2004, 05:36 PM
A few things... have you changed your tranny filter / fluid lately??
Another thing... have you examined your motor mounts? Maybe its the engine moving making al of that racket?!?! Just a thought.... let us know so that we can possibly help a little more.
WBoyd
05-24-2004, 07:30 PM
Fluid & Xmsn fluid is fine.
Not motor mounts.
Problem sounds like hard engagement internal to xmsn.
broughy84
05-24-2004, 11:49 PM
sounds like the reason you have to give it gas to get it in the gear (if i am reading this right) is because you may have a leaking pressure seal inside the trans. May be a piston, amy be something else. I think I would take this to a trans shop!
WBoyd
05-25-2004, 06:47 PM
Thanks for the advice. You are probably right that it needs a transmission shop expertise.
WBoyd
07-31-2004, 03:05 PM
7/31/04 - Took it to smsn shop and they said needed a rebuild for $2000. After 3 weeks this problem went away. The xmsn runs fine now. I think something was sticking inside transmission and eventually came unstuck.
98Lumina
08-01-2004, 02:58 PM
Transmission shops suck ass!
I was told six months ago that my transmission would lock up and become worthless if I drove another hundred miles unless I gave them $600.
That was six months and 11,000 miles ago and I haven't had a problem since. Go figure.
