idle problemscrabby760 05-24-2004, 03:43 PM after my car is fully warmed up... whenever i get to a stop and put it in neutral like waiting for light to turn greeen or a sto psign... my car idles down to like 100 and the motor shakes bad and tries to die then eventually it will die... if i dont keep reving... any ideas just got a valve adjustment thought that might be it but didnt fix the dying problem... crxlvr 05-24-2004, 08:31 PM check the throttle posistion sensor. and adjust the throttle cable also. crabby760 05-24-2004, 08:47 PM tommorow ima have a shop check my tps and stuff... crabby760 05-25-2004, 05:41 PM they think its a vacume line or something...could that be almxdupintegra 06-02-2004, 06:30 AM IAC valve, check that, CODE 14 crabby760 06-02-2004, 03:18 PM now the engine does the total oposite of that. now whenever i go to a stop the engine drops to 1,000 then goes up to 1800 never goes below that... what is the problem now... almxdupintegra 06-03-2004, 11:49 AM IAC valve, Idle Air Control crabby760 06-03-2004, 02:51 PM replaced the IAC VALVE.... still does it. Demolician 06-04-2004, 06:09 PM hmmm.... just wondering, but where is your coolant temp. gauge usually run at? and does it move when you stop the car? crabby760 06-04-2004, 06:26 PM little below middle and and it goe's to cold when turn off car almxdupintegra 06-06-2004, 11:51 AM thats normal jimmybvilla 06-08-2004, 03:34 PM My son's car 97 Civic revs up and down at neutral and sometimes when driving. I put in a fuel intake cleaner into the gasoline tank filled it up and so far the problem has not returned. I posted the problem under 92 + Civic in this AF forum and one replied that it did that when his oxygen sensor shorted. crabby760 06-08-2004, 03:44 PM i replaced the iac valve... my car still does t his crap... when i turn it on in the morning it revs like 2300 rpms.. then when it warms up it still stays at 1800 to 2000 it wont go lower... i rev it and it drops to 1,000 then split second later it bounces back up and idles at 1800 to 2000... i have no idea whats wrong but its ANNOYING and can't be good for the engine mechy1barry 06-08-2004, 04:50 PM have you tried the engine temp sensor? lots of probs with these.when they go wrong the computor senses cold all the time,hence high revs. crabby760 06-08-2004, 05:37 PM no where is this engine temp sensor.. and i'll replace it... jimmybvilla 06-09-2004, 10:38 AM Check out the Discussion forum for 92+ Civic. Look under The Honda Performance, Section 3 Intakes, IACV Problem. It is a similar problem to yours and the guy solved his problem. crabby760 06-09-2004, 02:56 PM that post just said to replace the throttle body gasket...? i have a custom made gasket on there rite now... maybe thats the case? ciryan 07-20-2004, 01:23 PM Did you ever resolve this issue? I'm interested to hear the results as I seem to be having a similar problem. ~Chris ricebrnr13 07-22-2004, 10:09 PM check the vaccum line from the pcv valve to the manifold. the same thing happened to my si. the line split. i've seen it on several others also. Automotive Network, Inc., Copyright ©2012
