Headlight problem
PhiberOptik
05-24-2004, 03:35 PM
OK it's a 99 Civic, in the past when I leftr my head lights on the little buzzer would go off when I open my door, it no longer does that. Also my lights on my gauge stopped lighting up, so I figure I blew some fuses, I dont have the fuse door which shows which fuse goes to what. Can anyone tell me what i need to fox to get these back? thanks
crxlvr
05-24-2004, 08:34 PM
just get a fuse tester and run it over the fuse panel, and replace whatver might be bad. im not sure where you can get the real diagram other than a chilton's, haynes, or helms manual.
PhiberOptik
05-24-2004, 08:36 PM
yea I did that and found the bad fuse for the gauges but the headlight alert still does not work and all the fuses are OK from the best as I can see
crxlvr
then the sensor in the door could be bad, does your door still chime when you open it?
PhiberOptik
05-24-2004, 08:38 PM
good question, I will check that next time I go outside, if that is the case is that hard to fix w/out a manual?
PhiberOptik
05-24-2004, 09:43 PM
the door chime does not go off when I open the door
b16a3sol
05-25-2004, 01:36 AM
sounds like the sensor is bad then. you can either replace it, or wire up another reminder for your headlights like the one of www.teamdelsol.com go to information, how-to, then lights on reminder. up to you which you want to do.
crxlvr
05-25-2004, 03:35 PM
the sensor in the door is easy to replace, it is just a button that any delaer should have in stock.
PhiberOptik
05-25-2004, 07:09 PM
OK I will look into doing that, appreciate the help
