JDM b18bSeverity 05-24-2004, 03:33 PM i got a JDM b18b from hmotorsonline and it had a broken part, i didn't want to bother trying to get a new one from them so i was hoping somebody here could help me out. it is a plastic piece that seems to be connected to the throttle body, here is a pic: http://img72.photobucket.com/albums/v219/severity420/123-2317_IMG.jpg i was thinking i could just get a new throttle body but i am not sure. it also came with a funky power steering pump, here is another pic: http://img72.photobucket.com/albums/v219/severity420/123-2321_IMG.jpg it seems like the placement for the hoses is way different than USDM motors, not sure if i need a new one. any input on this would be greatly appreciated. severity crxlvr 05-24-2004, 08:29 PM you should be able to buy that part from www.hondaautomotiveparts.com Severity 05-25-2004, 12:02 PM except that part is on a B18B which comes from an acura integra, not any hondas, unless they have JDM honda parts. i just wish i knew what the part was, i have the helms manual for a 94 integra and it doesn't seem to be in it. anybody else know what that thing is and if an aftermarket throttle body would work just fine? it seems like some sort of hose is attached to the part. and the power steering pump seems wrong........ crxlvr 05-25-2004, 03:31 PM ok ive found the part for you, unfortunatly it seems its only sold with the entire throttle body, so you may wanna call a junkyard and try to source one from an older integra, it should be the same as our USDM counterpart. Severity 05-25-2004, 04:52 PM i was thinking about replacing the stock throttle body with a BBK throttle body, do you think it would work? i would like to think it should..... here is the link for it: http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=211222&prmenbr=361 crxlvr 05-25-2004, 10:12 PM but the problem is that the part you need one be on the the new TB, you would still need it. Severity 05-26-2004, 03:01 PM damn.... do you know what the part actually is? like what is it called 'n stuff. is it really that necessary? thanks for your help. crxlvr 05-26-2004, 08:35 PM sorry to say im not sure what its for, buts its called a Dashpot Diaphragm. Severity 05-27-2004, 01:10 PM I FOUND OUT WHAT IT IS FOR!!!!!!!!!!!!!! don't ya just looooooove google?! here is a link to it: http://www.tocmp.com/manuals/Carbs/Holley/H2110-1957/MCarbHoll21101957/MCarbHoll2110195710.html looks like it is for automatic trannys. it says: Engines, equipped with automatic transmissions, use an anti-stall device called a dashpot. The dashpot affords protection against loading the engine when the accelerator pedal is suddenly released. The dashpot acts to retard the closing rate of the throttle as it approaches the idle posi tion. This gives the engine time to dissipate the raw fuel discharged into the intake manifold, thus overcoming the hazard of stalling. so, based on that, since i have a 5 speed manual gsr tranny, i don't really need this part, therefore i think i can infer that the BBK throttle body should work just fine for me. any other opinions are most welcome. drag1320neon 05-27-2004, 01:58 PM take that piece to any junk yard, you should find one there Severity 05-27-2004, 03:12 PM but i don't think i even need it, that article said the part was for auto trannys and i have a manual......... crxlvr 05-31-2004, 08:39 PM well try running the car without it and see what happens. if it is the case that you have an automatic motor, then your cams will be less agreesive than the manual ones, and will have less HP than normal. Severity 06-01-2004, 12:27 PM if that is true then why do car manufacturers list only one hp number for manual models and automatic models? wouldn't they have different numbers since the HP is based from the flywheel? i just don't see how the auto version of an engine would have different hp numbers than the manual version. the only difference should be the tranny and the dashpot dealy......at least that is the way i understand it....... jcrx 06-01-2004, 04:24 PM well try running the car without it and see what happens. if it is the case that you have an automatic motor, then your cams will be less agreesive than the manual ones, and will have less HP than normal. Bah, I want to see spec sheets on cam profiles before taking that internet urban legend to heart. I'm thinking that comes from weaker fuel maps, and more drivetrain loss. Severity 06-01-2004, 05:47 PM yeah, i thought that was a load of bs but i didn't want to be too rude.......... Automotive Network, Inc., Copyright ©2012
