Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 05-24-2004, 12:23 PM   #1
psanche
psanche Normal reputation
Unhappy damaged oil pan drain plug...(help!)
Did my first oil changed Saturday morning. Must have been the strong coffee. I over tightened the oil pan drain plug bolt and damaged the thread(ahh!!!).The bolt is stuck(just rotates and cannot be tightened), loose thread but no leaks so far.
Do I need a new oil pan? Thanks in advance.
psanche is offline   Reply With Quote
Old 05-24-2004, 01:17 PM   #2
rodeo02
rodeo02 Normal reputation
I don't know of any way out of it aside from an oil pan replacement. An aluminum oil pan & steel drain plug bolt is never a good setup You always want to wipe clean the plug threads & the mating surfaces of the plug & pan & just snug the plug by hand. As a way out of it, you could install a fumoto drain plug, or one of those fram sure drain plugs. That way it stays in place & you just open the valve to drain the oil. That may work for you.
G/luck
Joel
2008 Hyundai Santa Fe GLS AWD 2.7L
2008 Honda Odyssey LX chick magnet
Gone but not forgotten : 2007 Chevy Cobalt LS, 2001 Ford Windstar LX, 2005 Trailblazer LS 4x4, 2002 Isuzu Rodeo LS 4x4 & and many more.
rodeo02 is offline   Reply With Quote
Old 05-24-2004, 01:50 PM   #3
psanche
Re: damaged oil pan drain plug...(help!)
G/luck
Joel
Joel,
I heard about that fumoto drain plug. Doesn't it stick out too much underneath that it can get damaged? Thanks again. -Paul
Old 05-24-2004, 04:39 PM   #4
busboy4
busboy4 Normal reputation
FWIW I bought the fram quick drain and hated it. It was awkward and did not drain at anywhere near the normal rate. I removed it and do it the "old" way.
busboy4 is offline   Reply With Quote
Old 05-24-2004, 06:20 PM   #5
rodeo02
I've never tried the fram. I do have a fumoto on my isuzu & it works out great for that type of truck. Something like that might stick out into harms way on a low riding windstar.
Joel
Old 05-25-2004, 05:45 AM   #6
psanche
I think I'll stick with the plug.
How hard is it to change an oil pan from a scale of 1-10? A shop has quoted me $200 for labor alone!
Old 05-26-2004, 09:26 AM   #7
DRW1000
DRW1000 Normal reputation
Just a thought but can you tap it out one size larger and use a larger bolt? This should be able to be performed without removing the oil pan
DRW1000 is offline   Reply With Quote
Old 05-26-2004, 11:04 AM   #8
psanche
Re: Re: damaged oil pan drain plug...(help!)
I am going to try first to unscrew loose plug while pulling it and try a single-oversize plug. If I can't get it out then I'm replacing the pan.
Old 05-26-2004, 09:47 PM   #9
DRW1000
It may be a good idea after you "tap" with a larger (wider) bolt to loosen it and throw in a litre of cheap oil to flush out any shavings that may be in the pan due to cutting the larger hole.
Bookmarks
Google
Web AF
