header frying my cardjswain22 05-23-2004, 12:31 PM put an intake and header in the car and the engine lite is on and it says its running lean and the headers burning thru wires and stuff studballs 05-23-2004, 02:03 PM sounds like a bad install job to me...zip tie the wires so its not burning them...duh! droppedz 05-23-2004, 02:04 PM move the wires and stuff ?? What sais its running lean?? I have a header and intake and mine is running rich, and my engine light is on but thats because of a mismatch signal between my one o2 sensor and my o2 sensor simulater which is also the cause of running rich. droppedz 05-23-2004, 02:05 PM Oh and which header do you have ? perna00 05-23-2004, 04:24 PM if you increase the amount of air flowing through your intake/exhaust with a header, you naturally need to have more fuel injected into the engine to compensate for the increased air. it's possible you need more fuel pressure/larger injectors if your stock setup isn't delivering enough fuel to match the air. droppedz 05-23-2004, 05:27 PM So what do yea do when your getting to much fuel ? vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
