Do underdrive pulleys increase MPG?Metradyne 05-21-2004, 10:49 PM They're good for a few RWHP, but do they help out with fuel economy too? Nexagen 05-22-2004, 01:49 AM It's my personal opinion that anything that helps your car work less and perform more is always a good thing. And if more HP is delivered to your engine then it works less and performs more. So with this given I think it helps your get better MPG but not a whole lot I bet. You will probably get like a 2-3% improvement in mileage for more power output that your car burns less fuel. First of all the car you drive is most important. The things that impact a car are... 1)How heavy the car is... 2)How many cylinders the engine has 3)If it is V-Tec it usually tends to use a little more gas because higher torque demands more gas. 4)If you have a DOHC, you will burn gas faster then when comparing to SOHC. 5)Buy a 4 cylinder for commuting and for weekend street races save up for a Z06 C5 Vette from all the gas you saved. AFTERMARKET PARTS AND MODIFICATIONS IF you want to optimize your MPG to the FULLEST here is what you will need... 1) Superlight Racing Wheels that weigh less than 10 Lbs. 2) Superlight Ultra High Performance Racing Tires (If your wheels roll easier it's less stressful on your engine giving you better mileage. Imagine a Boulder to a marble...) 3) Injen or AEM Cold Air Intake (Clean filter every 3 months replace every 1 year.) 4) 4-1 High Flow Heat Resistant Headers 5) High Flow Catalytic Converter (Magnaflow or Dynomax Preferably) 6) Full Cat-Back Racing Exhaust System (Good ones: GReddy, Magnaflow, Borla) 7) Remove Spare Tire + Jack (Weight Reduction 40 Lbs+) 8) If you drive alone remove passenger airbag if possible (Weight Reduction 15+ Lbs) 9) If you dont listen to music alot... remove the stereo system (Weight Reduction 50-100 Lbs+) Get a CD Player and listen to your CD's. 10) Remove Undesired Panels from your car + any junk from engine compartment (Weight Reduction 20+ Lbs.) 11) Switch to Amsoil 2000 0W-30 Racing oil (GET THEIR ENGINE FLUSH FIRST) It's Nascar's Racing Oil and if Nascar pros use it, your should too. 12) Get NGK Iridium IX sparkplugs + Magnecor Racing Ignition Wires. Better ignition means better engine efficiency. 13) Buy Chevron Techron Fuel Injection Cleaner and add it to your tank every month. This fill free up lost power in your engine to contaminants. 14) If you can always buy Shell Gas. It's cleaner and lasts longer. 15) If your car only takes regular unleaded gas NEVER buy premium gas! The higher the octane the more less of a liquid and more of a gaseous for gas is. So in the summer it will evaporate up to 2 times faster than unleaded! 16) If you know how or if you know a speedshop, buy an overhaul kit and install it every 100K miles on your car to keep your engine running smooth, or just get stage 2 or 3 internals (The parts in your engine going High Performance). 17) If not needed, remove your AC for less weight and better MPG. 18) And of course get an AEM Tru Pulley Kit for your car if available. DRIVING HABITS 1) If you drive a stick always start it in 2nd gear and keep RPM'S below 3K whenever possible. Shift up early if you have time to drive and down shift earlier when you need to stop. 2) When going down a hill at more than a 33* Degree angle switch to neutral for as long as the downhill lasts and let the car roll on it's own weight. 3) Dont be a lead foot and pound the gas all the way... especially if there is a stop sign in front of you. 4)Drive at the speed limit or below the speed limit. If you constantly drive around 80-100 MPH you will lose gas faster due to the torque the engine needs to maintain that speed. 5)Avoid unecessary stops like stop signs and traffic lights. Try going the shortests distances with downhills and less stops. 6) Turn off your AC when driving. Open up your windows half way when driving but not all the way as this will make your car less aerodynamic. Acting as a parachute which will stress out your engine more. 7) Dont carry luggage with you on your car. Anything you dont need in a car should be removed. NOTES: Some people just get an Intake and an Exhaust and think that they will get better mileage right away. But that is only part of the breathing aspect of an engine. In order to get better MPH through natural asperated engines you need the whole spectrum of upgrades. The intake is the first part and then the engine does the work. Afterwards it needs to expel the waste through the exhaust. Which first needs to go out of the headers or extractors, and if you got stock headers and a high performance muffler... You are being restricted at the front by your stock low flow headers. Not giving you the full efficiency of your rear exhaust. Not only that... but if you got a stock catalytic converter it is also restricting both the headers and the exhaust. The cat converter connects the headers to the muffler exhaust. It's right in the middle and acts as a link that hooks up headers + exhaust so it's also in the way of the entire asperation system. So basically... Intake and Catback Exhaust is NOT ENOUGH The restrictions are stock headers and cat converter. What you need: 1)Cold Air Intake either AEM or Injen 2)Race Design 4-1 Headers w/ heat resistance 3)High Flow Catalytic Converter 4)Racing Cat-Back Exhaust. ZERO restrictions to airflow. I may be wrong in a few things but I hope this helps... -Nexagen Doug Rodrigues 05-23-2004, 03:32 AM Wow! What a thorough answer. I stand humbled. Hat's off and another "add to Nexagen's reputation" feedback. -Jayson- 05-23-2004, 12:12 PM i read the 4-2-1 headers gave more low end torque over 4-1 is that true? Automotive Network, Inc., Copyright ©2012
