1990 Cutlass supreme gage cluster odometer digits jumpingPAPAJACK 05-21-2004, 01:59 PM Hi, The digitial dash board (Gas gageSpeedometer and Odometer) on my 1990 Supreme LS is starting to mis-read the digits, The odometer moves 3 digits to the right and other times the whole display lights all the digits (as if in the test mode). Is this a voltage regulator problem? If i use the light dimmer for the dash intensity it sometimes works normal. Any help is appreciated. Slade901 05-22-2004, 10:49 AM Probably a couple of problems starting with leaking electrolytic capacitors, blown resistor and probably just needs to re-solder the IC (Integrated Chip) solder connections. Read my journey when I fixed my Digital Cluster on my 1990 Oldsmobile Cutlass Supreme 3.1L V6 http://www.geocities.com/southbeach/sands/2476/automobile/digital_instrument_cluster.htm Automotive Network, Inc., Copyright ©2012
