Any SHO owners in here?????
SHO411
05-20-2004, 04:31 PM
Not new to AF but never been in the Taurus side, just curious if there any SHO owners in here. I,ve got a 1990 Taurus SHO, 5speed. Well I am stripping it out, cuz I want the engine, harness and ECU for my project car.
Alex_Perry
05-24-2004, 01:11 PM
I've got a 93 ATX undergoing a complete 60k right now.
94SHO
05-28-2004, 09:16 AM
I have a 94 MTX...moonlight blue...glad to see some other SHO people..
Dr.Dogg
05-29-2004, 02:44 PM
sup all you sho owners i have my 3rd sho started with a 89 then 92 now my last one i think ill ever buy is this 94 think im about done on them,
Alex_Perry
05-30-2004, 12:21 AM
umm, I have no idea what you just said.
Autofreefindersguy
06-01-2004, 01:25 PM
Hey guys, I have a buddy considering buying a 94 SHO and was wondering the durability of the engine?
Any SHO forums for more info on this car?
Thanks much!
Doug
Alex_Perry
06-02-2004, 01:38 AM
www.shoforum.com
www.superhighoutput.com
www.shotimes.com
engine durability -- as long as regular maintenance is kept up, it'll go for a long time. If you fall behind or it's been neglected, it will fail sooner or later. You'll hear of a 60k when reading up on SHO's. It involves adjusting valve lash and replacing the timing belt, among other things. One way to tell whether it has been done recently is pull the spark plug wires off and look for oil in the spark plug wells. the seals that keep oil in the valve covers usually fail as the scheduled maintenance is due.
you also never mentioned if the 94 your buddy was looking at is an auto or manual. Not to scare you away from either, but both transmissions are prone to leaving you stranded. The auto's just fail because they can't handle the power, and with the manuals, the diff pin will shear and break through the transmission casing. Both have to be abused or maintenance neglected to die, so as long as you don't abuse the car while you own it and put money into keeping it running right, it will be a great ride. Also, try to get as much history on the car as possible.
Autofreefindersguy
06-02-2004, 02:48 PM
Thanks Perry,
Not sure about a timing belt being done in this car?
It has 183k miles and a hotter cam put in? Intake & exhaust mods...Its a 5 spd with a new clutch & trans...He has some nice Eibach lowering springs/shocks & 17" rims with Z rated Goodyear Eagles...For $1950?
I have seen it fly by my office so it sounds like it runs strong.
Alex_Perry
06-04-2004, 12:18 PM
I don't know whether he has 'hotter' cams in there. Don't forget, there are four of em. I would doubt it, they are really expensive, and up until a couple days ago, SHOShop (in California) was the only place to produce cams.
New clutch is a selling point, because it's a brutal job to have done.
With the exhast/suspension work done, it sounds like the PO liked the car. Unless it was beat on, definately consider it!
Autofreefindersguy
06-04-2004, 04:19 PM
Thanks again, yeah, Iam sure he has beat on it, I have seen him FLY by my office more then once...
He says his dad has a race shop and put the cam's in? I have no idea? How far have u seen these engines go? (I have also seem a trace amount of smoke)
deadlight
06-06-2004, 06:51 PM
Another owner here, I have a titanium 89 with the rod shifter conversion sitting on slicers. I think I've seen you on SHOforum Alex, I don't post there too often however.
Alex_Perry
06-06-2004, 11:13 PM
smoke isn't unusual if you know where its coming from. take a look at the end of the rear head on the pass. side (above the power steering pump). The cam sensor is there, and behind it, the cam seal tends to leak over time. It's a cheap fix. If the exhaust actually smokes, thats not good. I would avoid it.
They tend to go for a long time. they can go well beyond 200,000 miles assuming its maintained properly.
Deadlight, I don't usually post over at shoforum, more just like to read whats going on. Also, I used to be a regular on the TCCA, but i'm not too fond of it now.
shoble
06-28-2004, 10:44 PM
We own 5 Gen 1's (one is a plus model), 2 Gen 2's, and 2 Gen 3's SHO's. We also have a SHO-ble, 88 Mercury Sable with a 93 ATX drivetrain.
fajita23200
06-30-2004, 01:34 PM
I think he said he's done with them. Meaning, no more money spent(wasted) ever again!!!!
gbear711
08-30-2004, 07:47 PM
93 mtx forest green
FlamingTaco
08-30-2004, 11:12 PM
95mtx
sho_u
09-03-2004, 01:25 PM
i have a 94 atx
check it out
www.cardomain.com/id/bryanssho
93SHOcarguy
09-14-2004, 10:18 PM
I currently have 4 SHOs. 2 89 MTX, one I'm restoring and the other for parts. A 93 MTX that I'm hoping to get done this winter (Had an abrupt meeting with a light pole) and a 95 MTX. My 89 driver has 260k, the 93 has 135k and the 95 has 245k. They are an excellent car if well taken care of, but for that matter, most cars will be. I have a 95 GMC Sierra ext cab with 407k on it and the engine has never been open. Basic maintenance is all and I would much rather drive it than my wife's 98 POS er uh Windstar.
I have may SHO parts and access to many more, so let me know if you're looking for anything. Might be able to help.
meliss7567
03-19-2005, 08:33 PM
95 SHO Green, tan int., 134000 miles, recently replaced rack, other than that best car I have ever driven.
excidere
03-21-2005, 07:29 PM
Black 1990 SHO MTX - Restoration and Race project
Silver 1995 SE AX4OD - Daily Driver
I love the gen 1 tauruses and I finally got an sho to tear into, best damn car ford ever made :)
shorod
03-23-2005, 10:47 PM
I used to have a mint 1993 ATX (red). Traded that off for a Dodge Stealth R/T twin turbo, but missed the comfort of the SHO so I bought a '98 Green SHO as my daily driver. The '93 had 104k on it when I sold it, I never had any problems with it. The '98 just turned 80k, haven't had problems with it yet (but I don't think the cams are welded).
-Rod
th30n3th3ym1ss3d
04-11-2005, 03:05 PM
Have a 91 SHO just bought it in October of 2004 hoping to do the work my self and get the thing running to its potential after previous owner beat on it severly breakin 3 of the 4 springs but hopefully it won't die before I replace everything. Already have front 2 springs replaced and had to replace Crankshaft position sensor other then that love the car won't trade it for anything.
channing19
08-05-2011, 06:26 AM
43622
43623
43624
43625
43626I have had my 93 atx for about 3 months now!
shorod
08-05-2011, 07:34 AM
Welcome to the forum! I'm sure you'll enjoy your cliTaurus.
-Rod
