Help AsapJason Charette 05-19-2004, 10:15 AM I have a 1993 chevy lumina it is stalling and in drive and trying to die in while driving down the road. It is acting just like the fuel filter is clogged so I changed it sill didnt fix the problem. I thought ok maybe its the crank sensor so I changed it still didnt fix the problem. So I tried going in reverse drives great just when I put it in drive it dies. I dont get it. In park, neutral, and reverse everything is good to go. just drive messes up. So I figured maybe cpu changed it still didnt fix the problem. Please I need some help. Thankyou Feel free to page me if you want Ill call you back. http://www.metrocall.com/mcll/ go to send messege enter #361-744-2480 thankyou Jason Charette 05-19-2004, 01:51 PM still needing help Jeremy-WI 05-20-2004, 09:12 AM does it try to die at 45mph and higher? low speed or while applying the brakes? Jason Charette 05-20-2004, 09:37 AM all of the above but it drives great in reverse. every one says tcc I just cant find it Jeremy-WI 05-20-2004, 12:28 PM There should be a plug on the transmission just to the drivers side of the engine should have 3 or 4 wires going to it, one wire will be tan with a black stripe. Once you unplug the connector it should be fine. Check the RPO codes in your glove box for M13, MH1, ME9, or MD8. I don't know if a 93 Lumina would have an M13 but if it does, it will be a different procedure to fix Jason Charette 05-20-2004, 02:36 PM thankyou still looking cant find it you couldnt by chance send a pic? jasonc1001@yahoo.com SlamminMOfo 05-20-2004, 07:01 PM If its going fine in reverse, I dont think its TCC... when I had the TCC problem, Drive or Reverse would instantly stall the car until it cooled. kevinb70 05-21-2004, 12:40 AM check the vacuum line to your transaxle Jason Charette 05-24-2004, 09:13 AM Thankyou Ill look for the vac. Here is one for you I disconected the speed sensor car runs fine what is in the circuit for the speed sensor does any one know... Jason Charette 05-25-2004, 05:02 PM ??? Automotive Network, Inc., Copyright ©2012
