95' Riv Climate Controlddrdh4 05-19-2004, 09:52 AM The climate control for my 95 Riv reads about 75 deg. hotter that the accual outside temp. This seems to be causing my inside controls to think that the A/C should run all the time even when its only 30 deg. outside. Does any one have any idea what the problem is with the temp senser? ddrdh4 05-24-2004, 03:15 PM Can anyone tell me where the sensor(s) for the outside temp. setting is located on a 95 riviera? Also if can anyone tell me if the sensor goes bad can it cause the dispaly to read much high that the accual outside temp? and if there are replacement parts for them? Thanx for the help Don patanger2000 06-09-2004, 01:59 PM The temp sensor is located on the left bottom front of the radiator and can be found in your local parts store under "ambient temperature sensor" ddrdh4 06-28-2004, 01:56 PM The temp sensor is located on the left bottom front of the radiator and can be found in your local parts store under "ambient temperature sensor" Thank you for the information!! Don vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
